I thought you guys might be interested in a quick comparison of sockets. All of the pictures left to right are SnapOn - Craftsman - Toptul all are 1/2" 14mm sockets.
I haven't has a chance to put the TT to it's paces yet but the initial quality looks to be up there with the best. The SO is my tried and true goto socket and it's held up well. The chrome on the Cr is not as durable as the SO and is showing it's age even though it gets less use then the SO. For the money TT is a bargain cheapest of the bunch by far and it's much better looking then the Cr, dare I say just as nice as the SO. Time will tell how this new brand holds up.
Finish wise the best would be TT then SO and Cr. The TT has the whitest chrome and is nice inside and out. The SO finish is just as nice as the TT on the outside but the inside looks a bit unrefined. the TT looks like it was dipped in chrome where as the SO is a dull flat raw metal look to it. The Cr is a deeper smoked chrome color.
Size markings (easy to read) best is SO then Cr last is TT.
The SO as a nice deep engraving that is easy on the eyes. The Cr has the largest numbers but the depth of the engraving is shallow so it's a bit hard to read. The TT has very small numbers in a hex symbol which makes it hard to read.
Some Dimensions all in order of the pics (SO Cr TT):
overall height of socket - 37.81mm - 38.18mm - 37.57mm
diameter at drive end - 21.87mm - 22.00mm - 21.87mm
diameter at socket end - 20.42 - 20.63mm - 20.14mm (TT can get in tighter spaces)
minimum thickness of socket (at corners) - 2.10mm - 2.06mm - 1.91mm (SO thickest and strongest?)
depth of socket - 10.45mm - 10.45mm - 14.75mm (how deep a nut goes into the socket TT has the deepest and is the most versitile)
square drive dimension - 0.506in. - 0.506in. - 0.510in. (how tight it fits on ratchet)
size of socket (flats to flats) - 14.07mm - 14.17mm - 14.14mm (SO is tighest fit, I was always amazed at how my SO sockets could remove a nut that was rounded and would just slip with the Cr sockets)
the cost of the Toptul ?
