Socket for larger eye bolts/lag eyes?
NoahG
Detroit, MI
I use a fair number of eye bolts and eye lags, 1/4” thru 1/2”. Looking for a socket for the larger sizes. Tired of having to turn them with a screwdriver or a vice grip.
I have several wing nut drivers and sockets but they aren’t very useful over 1/4”.
johnre
Portland, OR
Get another "J" hook, either lag or machine thread, and cut off the thread portion. Then mount it in your drill / driver, select low range, hook the "J" into what you want to drive in, and give it just a little power until you get a feel for it.
Cutting off the threads avoids getting your drill chuck torn up or having too much runout.
Beerhippie
Far NE Oregon
I grind three flats on the threaded portion to fit the jaws of the chuck. Also works great for rebar tie wire.
drokihazan
Snap-On SPS10A will fit the 1/2" ones with a bit of slop. For 1/4", a Wing Nut socket will fit, like the Koken ones
Steve_P
Koken makes a few but may not be big enough for your task. As said, cheap solution is buy a cheap impact socket and get out the air tools to slice it up.
