I like your solution the best. I might need to get a small brake to make some of those.
-Jeff
I only used a brake, 'cause I have one. You could easily bend up those sides without one, as was done on that smaller tray. If I were to make those larger trays again, think I'd make the sides a bit lower, makes it easier to get the first one out. The stand-up socket tray does not matter as you can poke your little finger in it to remove a socket, which is usually what I do.
I was after a solution that uses the least amount of space and could still be installed in a shallow drawer. Works very well for me and they are easily made to any size that suits your needs.
