Catamount
A lot of guys don't like 'em, but I do. The plastic HF socket rails. Easy to interchange, and much cheaper than the Crapsman equivalent (and some guys say, more fragile).
Been using one of these for about ten years. I think mine is five deep. Plus a few extra rails on the side. They are awesome. You can set it up however you want if you get a bunch of extra clips.
http://tetoolsusa.com/tools/index.p...D=1638&zenid=92644ca1c8a5760b5a747627175d5eb2
A 1/4 piece of wood or plywood and dial rods could easily be customized to fit individual needs!!
You could just throw smack some nails into a piece of wood and it would work much better than you'd think it would. I'm that cheap but too lazy to do it, I think the lowes rails are probably cheaper than good quality wood (oak) there.
I really like these. Didn't you post a How-to on these somewhere?
I work the night stocking for Lowes, and those are non-stock according to the computer and will fade away. Get them while they are in stock, at $5 per a set of 3 in metric or SAE is a steal. Here's mine in action when I went in to retrieve a broken timing chain tensioner guide.
Nothing too special about my socket storage, but I did try one thing recently with favorable results...
I use Craftsman plastic rails which are ok, black for SAE gray for metric. They are somewhat overpriced for what you get, but not a big deal. Anyway, I picked up some HF knock-offs of these rails and they are pretty flimsy, not quite the same quality. However, the pegs are a little easier to remove the sockets from, which is a good thing. The Craftsman pegs are a little tight.
Since I ran out of pegs on the Craftsman rails I put some HF pegs on the Craftsman rails and I like the result. The pegs fit really snugly on the rail which keeps them from sliding unless you really want them to move.
And the HF rails are dirt cheap, so a blend of the 2 rail systems works out pretty good. Craftsman rails and HF pegs.
Thanks for the good ideas here, pretty cool stuff!
