Hey guys,
So I bought a brand new set of sunex shallow impact sockets to do a timing belt job on a 04 Toyota Tundra for a family member. Job went well, except one thing. I put my impact gun w/ the new 24mm socket onto the crank bolt and impact it off, and the socket was stuck to the bolt. Smacked it a few times with a hammer, nothing. Figured it'll loosen once I put it back on.
So did the water pump and timing belt, put the crank bolt back on and tighten it, and it was still stuck. Impacted it tight and loose a few times to try and knock it off, nothing. Hit it with a hammer, tried to pry it off, grabbed onto it with vise grips. It will not come off. So for now the truck is running great, it just has a socket stuck to it for the next mechanic who does a timing belt on it.
Any recommendations on how to get it off? I've never had this happen quite to this extent with any socket before. Its really stuck.
I could see going the other way and hammering a smaller socket onto a larger bolt. Also why can't you just slowly pry the socket off if the bolts already seated or at least partially seated? Maybe back the crank bolt out a bit so it's still engaged but you've got room and then stick a small pry bar in and work the socket off. Not that I'm advocating just prying away like the hulk against your crankshaft pulley but maybe you can get some motion with a light touch?
