crankshaftdan II
Has anyone out there had any luck or experience with the pressurized soda blasting equipment that is normally used for cleaning graffidi off of homes, buildings etc.??
had some car body panels soda blasted....had some surface rust...extent of my soda blasting experience.
I cleaned some motorcycle carbs using one of those $10 eBay blasting guns and a big box of baking soda.
They came out looking like new.
Everything within a 500 yard radius was white until it rained.
How did it work out for you? Did it work as well as using normal media?
Would you say that gun is practical for removing multiple layers of paint? I know the commercial guys can do it with their setups, but would these little guns? I'm talking about larger stuff, i.e. parts off my '46 (in my avatar) if I took individual parts one at a time? Mostly bumper brackets, etc but I'd be tempted to try a running board or a fender.
That coating also prevents the paint & primer from sticking so you have the scrub the **** out of the part with soap/water/scotchbrite before starting .refinishingIt leaves a coating to prevent flash rusting, Patrick
