Right side door has a 12” square light but it is on a separate switch and would remain off probably almost always. The soffit lights I’d be putting in would be 4 or 6” circular wafers.Does the entrance door have its own light?
Then I second the choice for #2.Right side door has a 12” square light but it is on a separate switch and would remain off probably almost always. The soffit lights I’d be putting in would be 4 or 6” circular wafers.
I had a similar setup and used that switch, cut the wire to the light in the attic, made a junction and tapped all the soffit lights off that junction.Right side door has a 12” square light but it is on a separate switch and would remain off probably almost always. The soffit lights I’d be putting in would be 4 or 6” circular wafers.
I am doing something similar. Those two wall lights on either side of the garage are no longer there and have been replaced by matching siding. I am going to use the switch that was tied to those to control the soffit lighting. I want to leave the actual square front door light in place for those cases where I need it to illuminate the step-in front of the door, such as when I have guests over and it's icy there.I had a similar setup and used that switch, cut the wire to the light in the attic, made a junction and tapped all the soffit lights off that junction.
Super easy and changed the switch to a WIFI on that turns on/off based on set times.
I bought the GE Cync ones w/ dimming and color changing capability a while back on a really great sale but I can't remember whether they are 4 or 6. Hoping that the spread angle will be good for it cause I am pretty much stuck w/ these ones.Buy a 4" and a 6" dimmable type. Many come with selectable color, (2700- 5000 Kelvin) even 2 different output levels.
Also consider beam spread (angle) while you demo one fixture between another.
#2 is better but I'd rather just have light at the doors only. Personally I've never much liked recessed lights here.
I put light by my front door so I can see the locks when I come home at night and look more welcoming and safer for guests. I also have landscape lights in the front yard to show the path to the door and accentuate landscape features.Not to blow up your plans, but......have you considered landscape lighting instead?
I have some small landscape lights but I just prefer the look of soffit lighting myself.Not to blow up your plans, but......have you considered landscape lighting instead?
Curb appeal is the primary goal. I just prefer the way they look vs other forms. Will probably have them shut off part way through the night. They will be dimmable and be able to change temperature (really unlimited color options) and will probably be kept very dim and warm-ish temperature.I have a few questions…
What do you want to do w/ the lightning? Goals
curb appeal
security light
you can get better results for both of those if you move the lights out away from the home
if the light is close or shines into the windows then the window blinds need to be down 100 % of the time - so that means no windows will be open for air flow during ideal times (not sure if you like that, some people Live 24/7 in AC )
will these be on dusk to dawn?
I have landscape lights on and they shut off around 1 am but run other lights D To D
That will look great.soffit lighting that is well placed, with low lumens and soft temperature.
I think the picture makes them look brighter than they are. These are only 100 lumen each.I agree with CD
Much better way to go. Plus, with that system in place you can easily add more lights further away from your house to illuminate landscape features or pathways. Lower output bulbs might be even better.
Yeah, 100 lumens sounds about right for that application. Good choice.I think the picture makes them look brighter than they are. These are only 100 lumen each.
I would do that but I have a motion security light/camera in the center.I think 3 lights over the garage would look better and give more light.
