Soft close drawer/cabinet converison
duc916
I am looking to convert the drawers and cabinets in my kitchecn to softclose. Has anyone done this? Any good or bad products I should look for?
BeachBoy
Blum
Search google. They make all the soft close, used by IKEA and cabinet manufacturers.
lksdrinker
I just installed a bunch of these in my kitchen this weekend. I used Liberty products from HD. Based on my experience I wished I had looked into what beachboy recommended; but I think the brand is BluMotion if I'm not mistaken. Looks like everyone who bothers to comment on that brand has nothing but good things to say. I'm not sure about the price difference between the two though.
The Liberty stuff I purchased at HD seems to work ok but the installation directions are completely worthless. They might as well just say "install these correctly on your drawers" b/c thats about as much info as they provide!
The drawer glides are very nice; but that seems to be the case only if they are installed 100% perfect which is a bit difficult since the instructions dont help much! If they are even slightly misaligned they dont work well at all. I also found that everything needed a good shot of silicone spray before the glides worked real well.
D
duc916
Thanks for the help. I will check into the Blum. There are so many different brands on the interner, you never know what is good versus ****.
Garageguy65
Spokane WA
Look into Accuride. Top quality soft close glides...
I also have Gliderite 100 lb full extension soft close slides.. Bought them off of ebay. Fairly cheap.
I prefer the Accurides over the Gliderite. Accurides are a little smoother. The Gliderites would work fine for your kitchen.
One thing to note each side mount soft close (accuride and gliderite) needs 1/2 inch clearance per side (1 inch total).. You only have 1/16 inch play +/- either way.
Order a set of Gliderites from ebay. See how you like them.
22" 100 lb full extension Gliderites run about $9 a pop
22" 100 lb full extension Accurides run about $16 a pop.
I think the ebay seller was "Gliderite"
cdestuck
Altoona, Pa
I had just did the same. I used custom service hardware. Great prices and they'll give you good info over the phone.
