Soft vice jaw covers
Vpross
St. Louis
I’ve been looking to buy a set of soft covers for my vice and have noticed they are made of everything. They are all around the same price so that doesn’t matter. Urethane, nylon, rubber, etc. Any input would be appreciated.
General Geoff
Allentown, Pennsylvania
I use copper jaw covers that I fabricated from leftover pipe.
I also have store-bought nylon inserts if copper is too hard.
mbshop
visalia ca
I have aluminum ones with magnets to hold them on to the jaws. They have grooves in them to help hold and position things. If that's still to hard then you will need the nylon or plastic ones.
MushCreek
Upstate South Carolina
I have one vise with steel jaws, and one with aluminum jaws that I made. If needed, I could always lay some sheet rubber in there to cradle something really fragile. Bear in ind that with enough force, even plastic can damage something. You can dent solid steel with a plastic hammer of you hit it hard enough.
HenryAZ
MEMBER EMERITUS
South Congress AZ
I use a folded piece of heavy leather. Place the item inside the leather then clamp in the vise. I got this idea from an excellent gunsmith (Don Williams), who holds slides and other metal gun parts that way.
matt_i
I take off the hard knurled jaws and put them in a drawer. I replace them with aluminum or copper jaws, make from solid bar stock.
98% of the stuff I put into the vise would not be acceptable to have the "bite marks" on them at the end of the project and so I regard the hard jaws as "for special projects only".
jimreed2160
Tallahassee FL
I guess I am too lazy or else my projects are too varied and too quick. Jaw covers take time to install/deinstall. I just use the bare jaws and pad my workpiece with a shop rag.
Rarified27
Between PA and NJ
I have two sets of soft molded rubber ones from Wilton and Bessey which are nearly identical except one has a magnetic strip and the other has two circular magnets. The strips barely hang on and aren't too useful. The circular magnets are great.
may0naise
Arizona
I just get a length of 2" angle aluminum stock from Home Depot and cut it into 6" lengths or whatever width your vice jaws happen to be. I like to get the 1/8" thick pieces. If they stock 3/16' that would be even better. Lowes might have a better selection of thickness.
I've found that putting the magnets on the squeeze side destroys the magnets pretty quick, so I epoxy them to the side that goes against the top of the vise. They tend to wiggle around a bit when the clamping presssure is applied, but snap back as soon as the clamping pressure is released. Saves the magnets from getting crushed.
Something like this: https://www.homedepot.com/p/Everbil...inum-Angle-with-1-8-in-Thick-801407/204273991
This 36" piece would yield 3 set of 6" jaws for less than $15.00
I did the same exact thing. cheap and easy, really you don't even need the magnets.
