Solar flood lights
2lows10
Hello all I own a local garden center and we recently had someone steal tires off one of our trucks, I been looking into solar flood lights to light up the compound do you guys have any suggestions
kd3pc
Northern Neck
You will likely be better served with a powered and/or motion activated light.
Unless you have a decent system (panel, controller, batteries, inverter and PLENTY of sunlight every day).....the hope that a powerful enough light will not be met. Without the inverter, you are limited to low voltage lights, which are generally not very bright.
rockwithjason
Las Vegas
You can get solar lights but there aint nothing flood about em. They wont even come close to what you want in a security light.
kbs2244
Sure.
But it gets to being a balancing act between size, cost, brightness, etc.
The panels are getting better every year,batteries as well.
But the cost of running line power would have to be pretty high to not make it the way to go.
