captain14
Good recycling job on the insulation. Did you get enough to finish completely yet. Every bit saved allows more tool money.
I can't imagine how much of a pain it was to clean your car out after hauling insulation in it!
What is Roxull offcuts? How do you get them to stay between the studs? Glue?
Good job packing that car full, and saving money by recycling all that (essentially new) insulation.
Will be nice to see the array go up on this, too bad grid tied systems don't allow you to pull any power for your own garage, but then with what they pay you per kw/h, it makes more sense anyways (assuming Alberta's rates are similar to Ontario's).
Good job saving money with the insulation that would have been in the land fill.... I am in Edmonton as well and I am VERY interested in how the Solar works for you! Please send me a PM if you want to chat about the solar off of your thread here... Sean![]()
How much would a solar system like this cost in materials?
Edge, your post is a very welcome thread of information. We were on the verge of microfit at the business (at 80c feed in!) just before the Ontario gov't pulled the pin on corporation owned properties. Your installation detail is awesome..please keep it coming.
Did you consider evacuated tube/hot water heat for your slab?
How difficult would it be to retrofit a solar power system like this to an existing garage?
I have a heated slab using an electric hot water tank and I would like to try and lower my energy costs somehow.
Ben, I suspect you'd get a better buzz for your buck doing a few evacuated tube arrays and storage tank to pre-heat water to your heater, particularly if you "overdrive" your slab during the day to store heat. It's hard to find examples of folks doing this, but the topic bears some investigation.
If you already have radiant heat in an insulated slab, then you have potential to store heat in your slab for release during night when the PV system is doing nothing.
