Solder Recommendations
kand3g
What is the best solder and flux to use on copper air and copper water lines?
03ranger
Wickenburg, AZ
Sil-Fos, no need to use flux. the phosphorus in the Sil-Fos serves as the fluxing agent and no separate flux is necessary.
csp
Franktown, CO
Sil-fos isn't really a solder though in terms of the process. It's more of a brazing rod and no propane or mapp gas torch is going to get hot enough to use it, if that's what the OP has for a heat source.
DC73
Lubbock TX
Google and then download the "Copper Tube Handbook". It has a lot of great information on copper pipes including soldering techniques and charts on pressure ratings. I could not find Stay-brite #8 easily when I started my copper airline project. Based on the chart in the handbook on "Pressure-Temperature Ratings of Soldered and Brazed Joints" (table 4a), I chose a 95/5 - Tin/Antimony solder which was readily available locally. It worked very well. I had no issues and no air leaks on first test.
Good luck,
DC
nadogail
Coronado, CA
I prefer 63/37 eutectic alloy for it's low melting point and almost nonexistent plastic state. Second choice of alloys would be 60/40 followed by 50/50 for low pressure compressed air work.
I am aware that solders containg lead is not allowed is not allowed in any potable water system.
zmaxmotorsports
South of omaha
Good luck,
DC
Stay Brite 8 is usually found at hvac supply houses.
