Soldering braided brush wires
darcyh
London Canada
Hi Everyone:
Installed new brushes in an electric lawnmower. Original brushes had the braided wire crimped to the stranded wire that fed the motor. The crimped combination wires were 'clamped' or held in place by the end or cap of the motor and brush cover.
I soldered the wires as opposed to crimping them. The solder connection was robust, and the end cap continues to clamp the wires.
Will this stand up okay, or should I go back and mechanically crimp the wires?
Its a Craftsman / Black & Decker mower.
Thanks
Dave
kiatech
Toledo, Ohio
Re: Soldering braded brush wires
Should have crimped and soldered, it may hold for a week or forever.
pepi
Woodstock, GA
I imagine you have taken out some of the flexibility of the assembly and it will fail/reduce the life of the part. Think about it.
The Cobbler
I was searching for some brushes that I couldn't replace & finally made my own by filing larger to fit... I searched extensively on the net & I do recall there was a reason for crimp & not soldered. just can't remember the reason
The Cobbler
I realize this an old thread. I have a cheap oscillating tool that quit. turned out to be the brush wire broke off the tab . nothing in my stash that was close enough to make work, so I drilled a small hole in the tab, compressed the spring & tied it together, soldered the wire to the tab with just a dab , re assembled everything & back to working again .
