bannerd
Hey all, first time soldering and had a heck of a time. The main water shut off was leaking like crazy. I bought a quick connect just in case. Ended up taking the shop vac and sucking water out of the pipe. From there I was able to flux the ball valve (sanded that and the pipe). Soldered the ball valve until it dripped out the bottom. Turn the main water back on and no leaks. Now I'm paranoid the water line is going to leak or the solder will bust apart.
The joint looks good, I'll post pictures in a few.
