soldering gun is this safe to use?
wazzabie
I have an older soldering gun 100 watts. The handle is still good but the case around the transformer is gone. The transform is completely exposed. If I plug this in and use it what is the risk of getting shocked? Could I just put a bunch of electrical tape around it?
bubinga
I would think that electrical tape would hamper the cooling abilities needed of the Transformer. There are usually vents in the case if I recall correctly. As far as getting shocked I am not sure without looking at it. Lots of times you can find the soldering guns pretty cheap for like five bucks at yard sales new or close to New.
Sent from my MotoG3 using Tapatalk
mbshop
visalia ca
Yea, they are not that expensive to take risks for a few bucks. I'm cheap and even I wouldn't risk using that.
W
wazzabie
I got a nos n the box weller soldering gun off ebay still with a receipt from 1968 for only $35. Great gun.
4xdog
Santa Fe, NM
One of my favorite lines in the movie Ronin is when De Niro's character says, "If there's any doubt, there is no doubt."
I tell myself that all the time now.
zendriver
Indiana
Ok, thanks.
I worked in defense electronic 30 years ago, where 50w was usually way too much heat.
Interesting enough, I'm teaching GFs grandson to solder today, so I'm having to try to remember a lot of it myself. :shocking:
W
wazzabie
The gun I got is a weller 140/100. It worked great on soldering some wires in a car and then heat wrap.
mbshop
visalia ca
I like that. And yea, subconsciously I normally follow that.
Two Speed
Ontario Canada
Ok, thanks.
A lot of todays multilayer boards need a lot of heat to get the joint sufficiently hot in order to melt the solder, they just sink the heat away. My goto anymore is a 100w pencil iron.
For your GF grandson, try and find some single layer boards to start on. You will be met with frustration if you are starting out with some old motherboards.
Alex.
MikeF2316
Thornhill, ON
I wouldn't use anything electrical that was broken like that, the penalty for bad luck is just too high.
My dad only ever had a soldering gun, but I was gifted a small iron when I was young. And I've always preferred irons since then, I have an 80 watt one that I use for heavy duty stuff, and a 30 watt one for the small stuff.
Lotek
Los Angeles, Ca.
100 watt soldering gun works great for soldering the defroster tabs back onto rear hatches after someone's kid broke them off. Flow in a bit of silver solder, then release trigger and use the gun tip to hold the tab in place until it cools. But yeah, I'd toss that one and buy a new one, cheap insurance.
Stadger
Just tape it up and use it. The transformer itself is not likely to shock you unless bare wires are present and you are careless.
driftpin
Anything electrical with bare wires/terminals/coils has crossed the threshold of it's "use-by" date. Scrap it or pitch it. You can never be 'too-safe' around electricity. My wife the E.E. will-be quick to tell you that, after a forty-one year career.
I have one that's probably 50+ years-old, it belonged to my father, but the case is still intact. I do have a modern Weller gun I bought not-long ago. I like the quick heat delivery, and it's dual-wattage choice. It's like having to grab the next-size hammer, just easier to do the job with the 'big gun.'
6PTsocket
That Weller 100/140 takes other tips like one that is great for cutting/fusing synthetic rope. There is another smoothing tip that is handy for plastic repairs. Back in the day, electronic stuff was a lot heavier and the gun was great for shields and buss bars.
