OP here,
I’m a ME. I’m dabbling in pcbs and perf board assemblies to help me do my job using arduino boards with the associated components to make my circuits work. Sometimes this means using the arduino output to control a 12v circuit using a 2n3904 transistor. Sometimes it means using a SFH620 optocoupler to pull an arduino pin high or low while isolating the other circuit and not allowing the electrons to intermingle.
The at home soldering iron will be used mostly for the new pcb or new perf board setup of through hole components. I might try getting into smd in the future, but for now, I’m only using through hole components.
Space is not at a premium for my designs.
Thanks for all the banter, insights, and passionate recommendations.
Sometimes the ubiquitous brands are not (either they never were or have gone downhill) that great. When I first started working on cars, I always used fram because that’s what my dad used. The common wisdom these days tells me fram is ****. Same thing with good year tires and Nike shoes.
It sounds like weller has not suffered from the same overinflated ego or quality decline.
