JackOfDiamonds
I want to solder 304 stainless to copper or aluminum to make a heatbreak for my 3D printer. Is it possible?
I have silver soldered lots of SS to copper/copper alloys such as brass and bronze. I assure you it works just fine.I do a lot of soldering for stained glass projects. I know you can't solder anything to aluminum. I've tried. Unless there is some special flux or something.
You can solder steel to copper easily, but it seems to my hazy memory that I tried soldering stainless steel welding rod to copper for a stained glass deal and was unsuccessful. If I recall correctly the solder wouldn't stick to the SS.
Well, I guess my memory was hazier than I thought. I was a certified arc welder but have no experience with gas torch welding. Is the brazing operation an oxy/acetylene process? My only experience with soldering is with an iron. It must take a lot more heat for the brazing operation.I have silver soldered lots of SS to copper/copper alloys such as brass and bronze. I assure you it works just fine.
Looks like the bigger problem is finding copper.
I always did it with a oxy/acetylene torch.Well, I guess my memory was hazier than I thought. I was a certified arc welder but have no experience with gas torch welding. Is the brazing operation an oxy/acetylene process? My only experience with soldering is with an iron. It must take a lot more heat for the brazing operation.
