Soldering stations & tools recommendations
Whitworth
I'm looking for info and opinions on (electronics) soldering equipment. What's the latest in features and go-to brands? I know professional computer repair guys can have thousands invested in heaters, microscopes, etc. I'm looking for an upgrade from the little soldering iron I got when I was a kid and any other must-haves for circuit board and computer repair.
Budget currently is $500.
Thank you.
justsam
Penngrove, California
Get a good magnifying light, and various fixtures, to hold your work. You will need solder extractors, both vacuum type and wicking braid.
I still use an old Weller soldering station with magnetic tips. I suspect others on here can recommend more up to date and integrated work stations, that will be well within your budget.
I would stick with Weller or Hakko to insure availability of replacement tips and other components.
cvairwerks
Within hearing distance of Texas Motor Speedway
Get something like a Weller WESD51 for basic work and then a nice hot air rework station to accompany it. Also a high quality lighted magnifier on an arm will be a great help unless you want to play with a tootsie roll camera and feed it to a monitor and work via that method.
6PTsocket
On the magnifier, the HF with 22 watt circiline fluorescent works great. I have had one for several months. I have no distortion issues and the arm stays where you put it. It even has upscale internal counterbalance springs. It comes with a daylight fluorescent. If you don't like that blueish white you can change it for a cool white or soft white for a few bucks; something you can't do with a permanant LED. The bulb even has a shield like an expensive Luxo. Save your coupons, it is cheap.
wxm
Hakko fx888. I have the digital version, works well.
Chief919
Waynesville NC
I will second the rework station. These days it's a must have.
You can't go wrong with Weller. Sometimes you can find the old ones cheap. Even the ones that don't have readouts or temp knobs are temperature controlled by the tip installed.
cvairwerks
The only problem with the older, non-adjustable stations is if you have to deal with RoHS compliant solders. Some of them will not give you enough heat to melt the solder until you have cooked the trace or the component. I've got a small Hakko station here on the bench for now, but will be upgrading it this next year and going back to a Weller station.
Davefr
OR
Get a Weller WX1010 with your choice of irons. (up to 200 watts). There's even a version that'll control up to two irons.
The station has Ethernet and USB. From the time you turn it on it'll be up to 850 degrees in about 10 seconds. You can program in the auto standby and shutdown times. Other then the power switch everything is touch screen.
They're made in Germany and Zoro sells them. Wait for a good coupon code.
Your budget should cover one. (just barely)
Make sure you get some sal ammoniac and tip tinner to maintain the irons tips
W
Whitworth
Thanks (all) for the info!
With the WX1010 Weller, how exactly is the USB port utilized? The product description says "parameter configuration and data logging" and I'm afraid that's a bit above my head, and examples of practical use may clear things up.
I'm also looking closely at the Hakko FX951.
Thanks!
Turner12
Recommend a Weller every time. Bought a Weller with magnatip in 1965, a lowly radio TV apprentice in northern England. Cost me two weeks wages. My peers thought I was crazy, changing from the old Weller 240 volt element 20 watt stick to this dinky little thing dangling on the end of a 24volt transformer. Two days later, "Can I borrow your iron" etc, etc. 15 second warmup, 60 watt output, iron plated tip that never needed a file to keep it in shape. Still have that iron as a third backup.
Go for a Weller with variable temperature control and readout. Hot air work stations are nice but overkill for general work,(essential if you intend to do much surface mount work). I use a relative cheap butane gas portable soldering tool with the air tip for the odd surface rework job. Old adage, 'horses for courses'!
Good light source, adjustable magnifier, clean bench, solder remover, a solder sucker, couple of those croc. clip adjustable component holders, a lump of plasticine, (modeling clay), spirit based fluxing liquid and a range of cored solders. A 25% solution of phosphoric acid is essential for tinning stainless surfaces. Hope this helps.
antinym
If you think you'll be unsoldering stuff, the hakko desolder gun is fantastic. Especially on multilayer boards or pcbs with big grounds. I also found kester 44 improved my soldering.
Personally, I picked up a X-TRONIC iron because I'm cheap.. I have no complaints other than it doesn't auto power off.
Brandon314159
Milwaukie, OR
The only soldering iron I'll reach for these days is a Metcal but you can get price gouged on those if you're not careful. That said I use them every day (I do circuit design, fabrication, and repair/diag) so a much more economical hobbyist grade unit would do for the average pereson. The metcals are hot by the time I flip it's switch and reach the wand to the PCB.
I've used the same iron to solder down components you can't see with your naked eye all the way to battery cable clamps for a battery charger. Impressive tool when you have the right tips ($).
penright
SW of Mustang, OK
Be sure and check out X-Tronic (https://www.xtronicusa.com/)
I bought the 5000 series (https://www.xtronicusa.com/#!/X-TRONIC-5000-SERIES-MODEL-5040-XTS-Hot-Air-Rework-Station-&-Preheating-Station/p/25881615)
They are made in Nebraska. Got to speak to the owner, really nice guy. I don't have any kind of affiliation to them, just like you when I was doing my research, all else being equal, they will have the parts in the future. I have had mine for about a year.
I have to agree with @antinym, I am cheap also. I am just a hobbyist so I don't use it often, but it has performed as expected.
justsam
That looks like a lot of work station for the money!
I suspect it is all Chinese import, sold and distributed from Nebraska, if that is important to folks.
penright
SW of Mustang, OK
The control probably is Chinese. I think there is one main one that everyone uses. Some of the other parts maybe. I would not be surprised if the chassis is stamped and folded in the US. I was under the impression for talking to them it is definitely designed and assembled in Nebraska.
