Solid oxygen torch?
BigE
Central Alabama
Found this among Grandpa's tools. From a quick search, it looks like very few parts are available. How well do these work? Worth piecing back together?
Sears 250.545150
Thanks
Bender78
Northwest CT
Man, I had one of those 35 years ago. It didn't work too well as I recall. Can you even get the O2 pellets any more?
brianh
grahamsville NY
I got one of those when I was 14 for Christmas the oxygen pellets burn erratically it was not an ideal setup to learn welding on, I did do a lot of brazing with it.
Soaking the pellets in flammable liquid made some interesting fireworks not that I recommend doing that.
BigE
Central Alabama
I don't plan to weld with it. I was looking for something closer to oxy/acetalene than propane in order to free rusted bolts and other general heating duties. A propane torch just can't get hot enough for those duties. Sears still sells some of the parts, like the frame and tubes. However, the oxygen side is toast and they don't sell any of that anymore. Think it might have some value to a fellow garagehead or should I just dispose of it?
tcianci
Walpole, Ma
Junk it, from what you're saying, you're planning to use it when you're already in the middle of a problem. It's doubtful that you're going to solve one problem with another problem
dtt454
missouri
somewhat on the same note though, dont waste your time with the small propane size oxygen cylinder setups either, they run out of gas (oxygen that is ) in just a few minutes.
Racer_X
MI
How about MAPP gas?
5lima30
Mountains of Western NC
+1 for Mapp gas I use mine all the time for general heating of rusty bolts etc instead of using my OA torch set. I use Mapp gas for my horseshoe art when bending them and save $$ instead of OA which has gotten pricey. YMMV.
