Sollus Ultra Not Booting
cavalry
Upstate NY
I have an old "soul less" ultra I used for quick and dirty jobs. It's been a tank but when I went to use the other day it it's stuck with some multi language message that it does not have a SD card installed. I popped the card out made sure everything was clean and still nothing. I can get into recovery with power/y/n but then what?
It's old and no longer supported, just wondering if there is anything that can be done before I toss it.
AJHD
Call Snap On or ask your dealer. Or find a dealer and ask them if you don't have one.
Under warranty/supported or not, I find it hard to believe at least one of those options won't answer a few questions for you.
Beyond that, it sounds like the SD card is corrupted or damaged. You could try buying a new SD card and attempting to copy the files or just try to access the SD card on another device. That should tell you if the SD card is toast.
If the software is fubar however, that's a different story. You would have to get a replacement from Snap On or a dealer.
You could also try finding a user manual. It doesn't have to be the exact model. See if they have any options for recovery. I've never looked and I don't have my Solus Edge anymore.
kadir34
Hızlı ve kirli işler için kullandığım eski bir "ruhsuz" ultra'm var. Bu bir tanktı ama geçen gün kullanmaya gittiğimde, SD kartının takılı olmadığına dair çoklu dil mesajıyla takılıp kaldı. Kartı çıkardım, her şeyin temiz olduğundan ve hala hiçbir şeyin olmadığından emin oldum. Güç/y/n ile iyileşmeye başlayabilirim ama sonra ne olacak?
Eski ve artık desteklenmiyor, sadece onu atmadan önce yapılabilecek bir şey olup olmadığını merak ediyorum.
Benim de solus edge'im var
kartım bozuldu
içindeki yazılımı bulamıyorum
sorunu çözdünüz mü?
kadir34
I have solus edge too
my card is broken
I can't find the software inside
did you solve it?
C
cavalry
Upstate NY
my card is broken
did you solve it?
I have not. I tried connecting with shop stream, that did not work. Directly reading the card does nothing. I guess I gave up and bought an Autel
