Solution for mounting lights on metal building
toyotadriver
I know this has been talked about in the past. I have a new house I've built and we sided it with metal. Of course, we are mounting lights on the outside of the building. I searched long and hard for something that would work to mount lights on the metal siding.
I finally found some Trex type decking material (not sure the brand) that had some grooves cut in the back that perfectly matched my siding. I cut pieces slightly larger than the lights we would be mounting, drilled a 1/2 inch hole in the center, and then screwed it to the metal. Mounted the lights to the decking material.
I was able to get a color that closely matched the siding.
Here's a couple pics:
T
toyotadriver
Thats neat ! cauk them holes, or you'll have insects/bees living there.
I might later.
I couldn't find any GOOD way to mount them and then one day, I was in the local hardware store and saw the deck material. The deck material was pretty expensive but I only needed 1 piece of each color that I needed.
bandaidmd
Delmarva side of Md.
one of the brands lowes sells is the same color all the way through and is available without the groove in the edge. It also is flat on both sides. I would rather sit on top of the small ribs and have a nice even 1/4"bead of caulk all around my block than those groves in the back.
cory58
Charlotte, NC
Toyotadriver - Just got my metal garage erected and your solution looks good. Did you get the decking at Lowes, HD, or some other store?
Thanks, Cory
cory58
Charlotte, NC
Update: toyotadriver helped me find a composite decking material either identical or very similar to the product he used. Here is the result on my building.
MountingBlock2_zpsuop8jknr by cory58f5, on Flickr
MountingBlock01_zps0is765ix by cory58f5, on Flickr
The product is TimberTech Terrain. It comes with grooved edges or straight edges. I will post more pics after I paint it the same color as the siding.
Thanks again toyotadriver.
Cory
cory58
Charlotte, NC
you could have mounted them directly and used half as much silicone.......
Ha! I don't 100% agree, but point is valid. It does take some caulk to seal up the sides.
Since the profile of the siding is very common, I was hoping to find a product made for the purpose, with the reverse profile of the siding. Best I can tell it does not exist. This is the closest I've found so far.
Maybe I'm paranoid about future leaks, but I think the majority of this mounting block being flush against the siding gives a much better chance of preventing leaks than a bunch of caulk all around the back of the junction box or anything else flat.
I also think it will look fairly clean once it's painted. We'll see about that.
Cory
