A&P mechanic
Hi GJ,
Big picture:
The on/off was leaking under the sink, so I removed the valve and capped it temporarily with a shark bite plug.
The new hollow nut for the shut off valve did not slide on the copper pipe since the pipe is distorted.
I pulled the copper ferrule off, the nut was likely tightened to much originally.
I will cut the bad piece of copper ½ inch pipe off and solder a new pipe extension on then install new compression shut off valve on this weekend.
I would like to temporarily plug the flexible line until I have time on Saturday in a few days to fix it correctly.
I went to Lowes tonight but did not see any compression plugs.
I did see compression caps but I need a plug.
I am not a plumber and am learning as I go.
Thank you in advance!
- Could you provide a link and the proper name for a compression plug to allow me to plug this 3/8 inch flexible water line temporarily please?
Big picture:
