Solvent dispenser?
jkpq45
I asked a professional mechanic to come help with my mower troubles a season or two ago--long story short, he had a really neat gadget.
It looked like an old-time plumbing torch, but had a nozzle that would allow a stream of whatever fluid was inside the can to stream out (he used gasoline). It had a schraeder valve so you could charge it with compressed air--made cleanup a breeze.
I'd like a few for bulk WD-40 and other oils, etc. Anybody seen what I'm talking about and know a source?
Thanks!
jkpq45
J
jkpq45
Looks like the Sure Shot A 1000 is up to $60 from some sources.
Here's an alternative (found after digging through old threads) for about half that:
Vaper Spot Sprayer
Wonder if the rebuild kits are interchangeable?
cosmik binturong
.fr
another alternative is the Gloria Profiline(shown ny none other than Monte of course!) range of stainless or plastic containers that you manually pump to pressurize.
no need for a compressor. :)
Monte
Germany
these are the most common professional manual pump sprayers over here made by Klaeger in Germany:
http://www.klaeger-plastik.com/klaeger-en/produkte/druckpumpen/index.php
available in the US and Canada here: http://www.fbs-online.com/FBS_home.html and there: http://www.uschem.com/index.cfm?page=productDetail&id=96&pid=3
more info:
http://www.fbs-online.com/pdf_files/Catalogue2008_Sprayers.pdf
