jstroede
Ok I have been wanting to do this for a long time, but other things have always seemed to get in the way. It has moved more to the forefront since solvent is harder to get and even harder to get rid of. I did this with stuff I had laying around, other than having to buy a couple fittings and a filter. So far it works great with only about a gallon on solvent.
I used a piece of wire mesh over the drain to catch anything big. It feeds down into a remote oil filter setup then into an old Holley blue fuel pump. I made a plate to rivet in where the old pump housing passed through, and got a bulkhead fitting to pass through. Everything is plumbed with 3/8 fuel line and brass fittings. The fitting for the drain was the hardest thing to find as mine was m14x2.0 and I had to wait to get it from China.
It is currently running off of a battery, but I will eventually find a compatible 12v power supply to use.
