Some bigger tools and ball joint tool
25mod
Martinsburg, IA
Prices are shipped.
Post and PM please.
1. Williams 1"dr 6pt impact socket 17-640 1-1/4" ($15)
2. OTC and Blue Point LARGE 3/4"dr sockets / hub sockets:
- OTC 1922 2-5/8"
- OTC 1825 3-3/4"
- OTC 1914 4"
- Blue Point ANS1909A 3-1/4" ....shop number stamped on top
- Blue Point ANS1910A 3-1/2" ...shop number stamped on top
ALL 5 shipped for ($70); pretty cheap at twenty some dollars a piece used.
3. KD Tools 3318 fork / ball joint seperator...great shape ($15) 11-1/4" long, forks are 2-1/2" to radius, 3" overall, forks are 1-1/2" apart, shaft is 7/8" striking surface just over 1"
4. Snap on L723H 3/4" drive slide bar with button; move your drive tool on it. Some dings and rust and lots of wear, but still very useable. 20" long
($14)
blacK20
How wide is the opening on that pickle fork? Can't seem to find any specs on it.
25mod
Martinsburg, IA
I will get dimensions for pickle fork and post in the morning if that is okay. I can also check diameter of the snap on 3/4 slide bar. I can say that your 3/4 drive snap on stuff or other should slide right on.
MJ
Deafautotech
Indianapolis, Indiana
ok, i have two snap on 3/4 drive tools but both have different shaft as one is older model and other is new model which has two different size of shaft..
i will send you a pm with list of tools that i am interest and see if can we work out??
25mod
Martinsburg, IA
Diameter of the 3/4" Snap On bar is 3/4-13/16 depending on how close and where you eye it; didn't use the calipers.
Pickle fork info I'll add above
