mach158
I would just like some clarification prior to wiring my shop that I am understanding everything correctly. Not sure how you guys can read those code books.
I plan to use 12 ga wire for everything, mainly cause I have a large roll of 12-3 nm-b now and figure their is no point in going any smaller then that plus I plan to run my outlets off a 20 amp breaker. I assume I will not need anything bigger then 12 ga (except for a few 240v runs which I know I will need 10 ga or possibly 8).
Now for wire staples I understand I must be within 8" of leaving the box whether its the panel, junction box or outlet/switch box and then I need a staple every 4.5' during the run of wire. Is this correct?
Also it is my understanding that at every outlet or switch I need 12" of extra wire outside of the box. Or is it 8"? Also this rule does not apply to a junction box correct?
Does it matter how many wires I put through a hole in a 2x4?
With the questions I have asked the County inspector about my sub panel wiring I am sure they are going to give things a good look and I want to impress them versus them having to come back out because I messed up.
