Some deck questions...
Innovate1
Illinois near St. Louis, Missouri
Talking to some contractors about deck replacement. One said they used cedar posts rather than treated posts as the treated posts can bow. I know the posts often have knots and grain that may cause bowing but all the 6 x 6 posts on the current deck still look straight. Said something about cedar beams also but thinking cedar isn't nearly as strong as treated lumber. Strength is more of an issue for beams than posts. Also mentioned they could paint the frame before the deck went on. I have seen this done in joist space in unfinished basements but never on decks. I question how well the paint will stick to treated lumber. Wanted to get some feedback here on both items. TIA.
matt_i
SE Michigan
I think cedar is a dodge for posts. What I would buy is UC4B aka Critical Structural posts. Use the peel + stick to exclude moisture from the horizontal pieces.
I also drew up a design to use reinforced concrete posts with a shimmable bolted saddle at the top, but you have to get very close on your elevations.
PCustoms
VT
PT is a tossup
I've bought pieces that should have twisted (based on grain/growth rings) stay dead straight and stuff that should have been fine twist.
I used over 10 6x6x10 and 4 4x4x8 on my deck 3 years ago and nothing went crazy. The 6x got some checking but that's all.
The 5/4 went noodly in a few spots and the 2x6 cap looks like **** with raised grain in more spots then not, plus one has a weird wave to it that I probably should replace
couch67
Ontario Canada
I'd stick with PT framing for a basic deck. The understructure doenst need paint - Is it going to be visible, and that is why they suggested?
Make sure it has good ventilation underneath, that is key for it to last. I like using deck tape on top of the joists.
jar944
Northern VA
Get treated clear (as possible), centered heart 6x6s and they shouldn't bow. You might (will) be picking through the pile to get them
Rusted Nut
Northern Arizona
Cedar is very seldomly used as structural lumber. Fence posts yes, deck post or beams probably not. Ask contractor to show the span tables in the building code that allows this.
Burt Shaver
Iroquois, Ontario Canada
The few decks I have built I have used PT, green PT is not available here anymore so it was the brown PT, forget what it’s called. I used synthetic roofing underlayment to cover the tops of the beams and joists. I seen someone mention deck tape for the tops of the joists here, that might be easier than the synthetic I used but the idea is the same, don’t wrap the entire joist or beam, just keep the water from laying on it and the frame should last many years.
YeCats
South Carolina
How old are you and/or how long do you plan to stay at this house?
At 65, I built my deck with PT. Figed it would outlast me.
mikedodge
I haven't seen PT posts bow but maybe that's a regional thing depending on where they are from or how long they need to be?
It usually comes down to cost, they both have similar life span.
Viper98912
GA
I've seen cedar for fences, playsets, and decorative pergolas, but never for a deck structure. But, I'm not a deck expert and don't do it for a living. But I did build my own deck from 6x6 PT and I did stay at a Holiday Inn once.
I
Innovate1
I know it doesn't NEED paint - it's purely cosmetic. It's a deck on the main level above a walk out basement with patio below. So it is visible. It's also on the north side so it has a minor amount of green - see the pic of the existing 20 year old framing. I don't think the paint would eliminate the green staining - think it would still happen on top of the paint. I get a bit on the top of the composite decking also and have read I should hose it down occasionally to minimize that - maybe every 2 to 4 weeks. Have considered some way to keep it dry underneath but that will trap more moisture. Seems better/simpler to make a wood rack with a top to keep a small amount of fire wood on the patio dry. Do plan to have the posts wrapped similar to in the pic. Deck underside.jpg
I
Innovate1
Think I will have them use treated posts and lumber. Have seen some treated 4 x 4s that warped a lot but not 6 x 6. I suppose it can happen but they usually already have some warping so could be spotted before install. And replacement of a post if they do warp doesn't seem like a major issue.
jar944
Northern VA
Epdm
Screenshot_20260508_153332_Gallery.jpgScreenshot_20260503_083515_Gallery.jpg20231202_112744.jpg
beltfeed
USA
Go to Home Depot or Lowes, they have plenty of bowed PT on display. :LOL:
