Some great compressed air resources.
Luckydevil
Tampa
Flow capacity and pressure drop:
http://www.engineersedge.com/pipe_flow_capacity.htm
OSHA info on PVC being used for compressed air:
http://www.osha.gov/dts/hib/hib_data/hib19880520.html
Excellent tech info and faq guide:
http://www.airheads.net/tech/index.html
Plastic Pipe Institute regarding the use of PVC to carry compressed air:
http://www.cagi.org/pdfs/Tech Sheet 101.pdf
Shop Air Piping Layout Diagrams:
http://www.sharpe1.com/dr-pipe.htm
Compressed Air Piping Systems:
http://www.ecompressedair.com/library/piping.shtml
eschoendorff
I hope you don't mind
but I sent a link to your post to a friend who was looking for this very info. Nice job on the research... thanks!!!! :beer:
L
Luckydevil
Tampa
I can't take credit for someone else's work. The first three I found on the Grassroots Motorsports website (www.grmotorsports.com), and the last two I got from one of our own member's posts (bdaz442).
avsfan733
Rochester
i attatched two pictures from my schools recent watermelon launching competition, they are of nother teasms air cannon. They ran it up to 100psi 4 times. After the forth they noticed some surface cracks...we put it in an isolation chamber (cement block building we use for peressure testing thigns like this) and watched it blow to pieces at 75 PSI.
The flexed piece of pipe was used as basically a piston rod but ya...That was big PVC and only at 100psi...after looking at it in ansys and doing some fatigue modeling we came to the rough conclusion that 90PSi being cycled quickly was enough to cause an eventual fatigue failure. (giving it an uncertainty and some minor flaws trying to simulate any pipe damage or problems in gluing) 60cycles to failure.
