aunsafe2015
Installing a Mitsubishi hyperheat 9k unit in the next week or two. Having an HVAC guy do the pressure test, vacuum, and initial turn on, but I'll probably do the rest.
1) Mitsubishi calls for a 3" hole and wall sleeve. What are people using for the sleeve, and where are you buying it? Any problem just using a plain old PVC pipe as the wall sleeve? Is a full 3" required or could I get by with 2 or 2.5? Lineset for the 9k unit is 1/4 and 3/8.
2) Does your drywall have to be up before you mount your wall plate? I tore down drywall to install foam insulation. I suppose I could put up a few square feet of drywall just where I plan to mount the wallplate, but it will be a few weeks before I get drywall back up over the entire wall, and I'd rather get the mini split up and running before then...
3) Any problem mounting the wall plate to a 2x8 header above a window? I will not drill the lineset hole though the header but can the rest of the plate be mounted on/screwed into the header?
Thanks!
Thanks!
