Thank you for the kudos.
Technically the water pump isn't fully functional yet, I did shorten up the garden hose today, so it should be all clear for take off. Tomorrow I need to finish and fix the electrical for the AC and the welder, I know if I don't it will stay that way for too long. Maybe after lunch I can get the pressure washer fired up. Probably won't get the compressor tank done, because I need to set up the crane for that. Who knows what will happen, I have ten things going at once, but I am seeing forward progress so far in almost all directions (a bit slow at times, but no one is perfect).
Another friend is supposed to come down later this week and drop off some steel for me, then I am selling him some I beams and maybe some other stuff. I would like to get the batteries out of the 5 ton and see if any are good. If two of them are still good, then I can rework the cables to make do, if not I am going to find a couple used batteries to at least get it starting without a boost every time. I am curious to see if my new booster pack has enough nut to start it without any batteries, according to the specs it should do it, but real world can be different.
I also had a great idea for the new 100' cord reel (I will post pictures tomorrow of all the stuff from zoro), I am going to put it outside in an enclosure of some sort, but the cool part is what I think I can do. I want to set it up so it is on a big hinge that will allow it to sit flat in the enclosure, then pivot out so it is easy to get to the side yard, but I also want the hinge to allow the reel to pivot around the corner of the building, that way I can use it out front as well. I have an image in my head of how it will work, I need to do a bit of drawing to see if it will work.
Anyways I am getting to worked up and may never fall asleep now, it has been a long day as I was up a bit after 4 AM. Have a good night guys.
