Sometimes you need a square hole and can't wait
whateg01
doo dah, kansas, usa
Had to make some 11mm square holes for carriage bolts for a customer. A little time at the mill and the lathe and the welding bench and this thing worked a treat. A broach would have done the job but no time to wait for one in a size I might never use again.
The one on the right was the sample part.
W
whateg01
Saves a lot of filing! You just press that through? Looks like a nice clean hole.
Yeah, drilled a 7/16" hole then pressed it. I was curious how much force it took but every hole I forgot to look at the pressure gauge. I might do another just to look at that. I'm curious if I could have done it in the arbor press.
gba2331
For our HS robotics team, we use sprockets on a hex shaft but I always wondered how they made a hex hole - do you think they could have punched this as well, or is it from an extruded blank that is machined?
Hohn
Diesel Central, Indiana
You can grind that ID if you have sophisticated enough machines, but typically it's broached.
Citation
Indy
I agree with those who suggest broaching. Basic broaches aren't too expensive.
W
whateg01
Can't tell what material that is but for robotics, it could be aluminum. If so, it's very possible for it to be an extrusion.
gba2331
That was my thought also, but that leaves a lot of material to be removed to make the gear.
RoninB4
Under My House
By my way of thinking, there's no way those work, but they do (once again, no one seems to care what I think). Needs a mill or hell-for-stout DP.
-I had my doubts about them too until I used one, I was delighted for the rest of the day. There's enough info about rotary broaching, including specs, to make one yourself. There's limits but any number of flats between 2-6 are attainable for a reasonably equipped home shop IIRC.
"once again, no one seems to care what I think"
-Maybe but I still read your posts before deciding. :badteeth:
Beerhippie
Far NE Oregon
I've seen videos--maybe This Old Tony?--of folks making them. I don't have the tooling to make or use one, but do have the occasional need for one, which is why I have some small files and a modicum of patience.
RoninB4
Under My House
-I did post that a "reasonably equipped" home shop should be able to make one but I guess that I have a rather skewed notion of what "reasonable" is or should be for others. My opinion doesn't always count either.
RoninB4
Under My House
-If the material is shim stock (.025 or less) there's a small, inexpensive, hand held shear for internal hole shapes I could suggest. Won't work for thicker material but for thinner material it's much faster than files and can cut relatively sharp corners from a hole as small as 7/16" IIRC. Thought you (or somebody) might want to know.
cannuck
Rural SK
That guy is going to be hard on quill bearings.
IMHO it is very inappropriate to call this "drilling" as most larger drill presses use Morse taper quills - without a pull-in bolt - so no way to use with side loads. Smaller presses that use a screw-on chuck don't have enough quill rigidity or tight enough fit to cut accurately. You also would need to chuck it up in an indexing boring head. This is a milling operation (and even then you would need a good one). Not to deny, though, this is a ****** brilliant bit of tooling.
IndyGarage
Indy
My plasma table is down until I get the pi setup to run it tired of constantly replacing the Dell computers I've been using.
I don't have a table. I just bought a set of templates for round holes, square holes and oval holes - you just mark the location clamp the template on and cut the square.
Beerhippie
Far NE Oregon
Do you have a link for those? Do they come in different offsets for different drag points?
T444e
I have a project I'm working on and need square holes for a number 10 carriage bolts. I'm using a HSS square blank a that I ground a taper on and slitted the corners to make a broach to use in the arbor press. Proof of concept worked. However, my transfering of hole locations to the steel I need to broach was a failure. I realized to get back on the project and have a better method of hole layout to try.
W
whateg01
I made the rounds part just a little longer than the thickness of the part so it registers the location. Getting the square punch and die clocked correctly made me a little nervous, but on the one hope where it moved and was way off, it just pinched a thin layer of metal between them so no harm was done.
