Sommer Door Opener - Side Mount Kit
Cinch01
Ontario, Canada
Anyone install a sommer opener with the side mount kit? ie. Installing the opener rail sideways above the door rail on the side?
Also, any Canadians purchase such an outfit here - (Ontario?).
I did search and find some info on sommer openers, but found no direct experience with the side mount.
Thanks for any info!!
Matt M PA
SE PA
I have two Sommer openers in my garage.
On one, I wanted to use the same kit so that the opener would not be in the middle...above a mid-rise lift. The folks at Sommer told me I could mount the opener in the standard manner...except off to the side almost above the one door track. Providing the door uses a torsion spring, you can mount to the side with no problem. No kit required.
C
Cinch01
Ontario, Canada
I see... Thanks for the pic - that could very well be an option for me. I have to see if there is any difference in clearance required to do it that way as opposed to the actual side mount option. By the looks of your pic, I could have the space to do it that way. You can see by the pic attached here what I have to work with - beams on each side of the track, joists not too far above... and I don't want anything in the middle of the ceiling where I have lighting - and don't want to lose the headroom anyways in the middle.
EDIT: Sorry for the small pic!
Matt M PA
SE PA
You'd just mount it inboard of either track...connect at the upper corner of the door where the top wheel is. I can post any other pics you might like to see.
voipguy
I just installed two on my new Wayne Dalton doors. I have 12' ceiling and didn't want the obtrusive look of the opener unit and track hanging down from the ceiling. Kit is ~$66 and bracket is well built.
Looking at you picture it should work fine. They have a video on their site of the side mount kit in action.
Scott
