My garage is small, and I wanted a welding table because I was tired of working on the floor. But I also needed a work bench.
My local steel supplier does not sell by the # and doesn't sell remnants so you must buy the whole sheet, so I cropped up a plan to use a 4x8 sheet to make two 2x5' work benches and sold the 3x4 sheet left over on CL.
Here is what I ended up with. It's not *perfectly* square on top, since it was sheared, is about 1/8" off flat from edge to edge length wise but it'll work for now.
I used 3/8" top and 1/8" 2x2 tubing. The bottom shelf is 13 gauge 1/2" expanded metal. The casters I cheapened out on and went with Amazon specials. They are 5" stem casters that thread into a nut I welded on the bottom.
I'm not totally sure if I will paint it or not, as it would require a lot of scrubbing to get all the oil off. I do plan to customize it a little more at least with one being a dedicated welding area; I plan to put some hooks and hang my helmet and grinder on it.
