Sorting thru my taps...
Noworries
Southern California
I was organizing my tap drawer yesterday. My largest non npt is a 3/4-10... I have only ever used my 1/2 and larger taps to dress up threads so i got to thinking how difficult would it be to tap a 3/4 hole by hand in 1/2" or better steel. Anyone with experience doing this?
ez-duzit
Marina del Rey
I have. Used an extra-large adjustable wrench with a cheater because, at the time, I didn't own an adequate tap handle.
lilscorpion
Colorado
It’s doable but you will need leverage. The filler the tap, the more you’ll need. You’ll want to use tap magic or some other cutting/tapping fluid.
Oh and I’ve hand cut 1” fine threads.
dutchgray
Dorset. England.
I have a tap wrench which is 21 1/2" long and some big taps, but I think M12 might be the largest new thread I have tapped by hand. Makes light work having a large tap wrench though.
I might have to try out one of my real big taps and report back, 1 1/2" Whitworth is probably the biggest I have.
Sliceddeuce
I Put The tap in my Index 745, toss it in low and flood w/ Tap-Magic. Done deal. Unless the part is on the long side..then it goes on the lathe, set the gearbox for correct pitch and watch the old boy work.
karacjohnson
we do at work quite often, typically use rapidtap and just use a 12 point socket to hold the tap with a ratchet. we do this up to m30 without much effort.
matt_i
If your tap is centered over the pilot hole and the tap is sharp, its not that big of a deal.
Rigid setup with a spindle machine as several described above is of course the most reliable way to keep the alignment.
I would do this with a magnet drill press if the part/assembly could not be put into a stationary machine.
Milton Shaw
I have threaded 2" pipe with Ridgid threaders by hand. I now have a 300 power threader that sure does make it a lot easier. I have pipe taps but have not had to use them except to clean up threads so I cannot say how hard they would be to turn.
Monza Harry
Windsor ON
The bigger machines at work often "Get Scared" and leave the bottom 1" or so untapped. so the mould-makers (that includes me!:lol_hitti) have to finish the eyebolt holes, I've done 8 2-4 1/2 NC holes in an afternoon, this past Wednesday it was 8 1 1/4-7 holes 3/4" deeper. our big wrench is around 4' long though, a 2' wrench wouldn't be very good you would likely end up breaking the tap because it would be very tough to apply even enough pressure at that torque level. Harry
