ford33
I am installing ceramic tile flooring in a second story condo. The floor substrate is exterior grade plywood and the existing floor covering is carpet with pad. Although the condo board does not require noise reduction material be used under tile, I want to avoid noise complaints from the first floor resident.
I have seen products offered for under-tile installations but they all seem expensive. Some are as low as $2.50 per sq foot with many much higher.
I am not looking for a decoupling mat as that provides no noise suppression.
Anyone have a recommendation for a suitable noise suppressant underlayment product for use with ceramic tile? Or a supply source for such material in the Chicago area?
Remember this is a tile floor and requires a sturdy firm underlayment or the tile and grout will certainly crack. Waterproof is not a requirement. Tile size is 16X16 if that matters.
