Soundproofing Walls?
karoc
Hemphill Tx
Options: I want to soundproof walls for our utility rm and the bathroom. Rockwool has their sound proof batts which I can get at Lowe’s. 79.00 for 59 sq ft per bag I would need 8 bags so little over 600.00. I’ll probably bit bullet on this, but are there more choices?
What’s out there that would do same thing but maybe cheaper? It’s our 1000sq ft retirement home so there’s not lot room, we want keep bathroom sounds down and don’t want hear washer going. Any suggestions on soundproofing room? Tks
Meames01
Back Yard
Are you building or remodeling this ? The reason I ask is there is a framing method that greatly helps with sound proofing a wall. Would still need some insulation / sound barrier to be completely efficient though.
Anyway, if you're building the room / wall, install 2x6's as top and bottom plates. Then frame traditionally with 2x4's 16" OC, but stagger them on the 2x6 plates. Basically, one side of the wall will have 2x4's offset from the other side. This will ensure the sound isn't traveling through the wood framing. I hope I explained it correctly so it's makes sense.
We built our bathrooms this way and they are practically soundproof with no added insulation. Good Luck !
K
karoc
Hemphill Tx
Meames01 wow, that sounds like good idea and I understand. But I have my walls framed and one sided. I think I’m just going go with Rockwool just to keep it simple for me and Lowes shows it’s in stock👍 Thanks for sharing your method
Rusted Nut
Northern Arizona
Best sound proofing comes from separating the two sides of the wall, as Meames01 stated. Sound batts are icing on the cake after that. Hat channel works well too.
66Caprice
Stanwood, Washington
dcg9381
Austin, TX
Pretty good article on it:
Commercial spaces often use acoustic panels, which may help. They're hung post construction.
Sounds level of the appliances is another huge factor.
jade97
When I finished the basement in my old house, I used regular insulation in the interior walls. There was a wall between the 'bedroom' and the HVAC closet and you could not hear the HVAC running, except for the air noise from the ducts.
K
karoc
Hemphill Tx
Our AC is also in utility rm, but with these good suggestions I believe I won’t have noise problem. Thanks guys
duneslider
Riverton, Utah
Mass is what is needed to reduce sound. I put rockwool between my room and the laundry room and can still hear the washer but it isn't loud enough to be an issue, we don't do a lot of laundry during the night though...
In addition, if you even just bump the drywall up to 5/8" on those walls it helps. Keep any outlets and switches out of those walls, or if you need them add putty pads around the boxes. If air can get through, sound can get through.
RC-1 Resilient channel is a cheap and easy upgrade as well that makes a pretty big difference.
Adding mass loaded vinyl also makes a big difference.
All this stuff adds cost obviously, so you have to decide how much sound reduction you are willing to buy.
Jeff Ivers
Oklahoma
It all depends on whether your goal is "sound proof" or "sound reduction" and how much you want to spend. My master bedroom shares a wall with the laundry room. It was insulated with standard fiberglass bats and the noise of the washer and dryer running does not interfere with sleep, providing doors to bedroom and laundry room are closed. If rock wool is more expensive than fiberglass, I would not spend the extra money.
billconner
Thousand Islands NYS
Mass - as many have pointed out (double or tripple 1/2"); some fuzz in the cavity - thin is fine but at least 3 PCF; and if you can afford the room mount drywall on one side with resilient channels, as also noted. Avoid back to back electrical and other penetrations. Seal (butyl caulk) all gaps. Avoid flanking routes - like through a thin ceiling and back through it or through floor. No common ducts. Gasket doors.
Dig Doug
Just buy a really loud fart fan ! and set it on a motion switch so it turns on when you walk in….
Problem solved
lol
Super38ACP
Scruffy City (Knoxville)
I have both the R13 rockwool and the normal one (cant tell any real difference in them) and it does help cut down on sound. It's not remarkable but noticeable. It is enough i'll continue to put it in during the remodel.
billconner
egdede
OP as you have plates and one face of drywall installed 1) use the wool, 2) use resiliant channel to decouple the other face of drywall and 3) consider a second layer nof drywall. You will have very good results if you can do all 3.
make sure you don't pinch the resiliant channel by using too long a screw.
