Source for really small masonry drill bits (1/16 or smaller)
nes999
IL
Does anyone know where I could buy masonry drill bits that are 1/16" or smaller?
Our RC club is wanting to sink some bits metal (1/32" rod) into some scale concrete barriers. The best way I can think of is to drill and back fill with epoxy. The barriers are made of vinyl concrete patch.
CGT80
IE, SoCal, USA
You shouldn't need masonry bits, as it sounds like the patch is made from a form of vinyl. Drill bits under 1/16" will be less common, but out there. x2 on drilling with a 1/16" and using glue, epoxy, silicone or other adhesive.
Have you tried a run of the mill 1/16" bit in that material yet?
N
nes999
IL
I haven't tried a normal bit yet. I wont be over that way until next weekend.
I believe this is what the we will be drilling.
https://www.quikrete.com/productlines/vinylconcretepatcher.asp
6PTsocket
That stuff has sand in it. You are not going in with a nail or a regular twist drill. Masonary bits have a piece of carbide brazed to the tip of a steel bit. In the smaller sizes you can get a solid carbide bit. A brazed carbide tip is not workable in the tiny sizes.They are actually easy to find. Just google" solid carbide bit". Amazon has a bunch of them. They are used for things like drilling the better printed circuit boards that are glass filled and would dull a regular bit very fast. 1/16,1/32 and much smaller are available.
N
nes999
IL
Thanks, I ordered some. Didn't even cross my mind.
Sent from my VS988 using Tapatalk
rlitman
Long Island
They're readily available, and also incredibly fragile. Like trying to drill with a glass fiber fragile. And they need to be run at REALLY high speeds. But once you're past all that...
I'd suggest a different angle. Use a dental drill.
driftpin
Dremel has a drill press adapter available at the Big Orange Box store
6PTsocket
A dental bit is actually more like a burr, for grinding out a pocket. It is not really made to drill a straight hole. Also the shank tapers to a larger diameter right behind the tiny burr.
rlitman
Long Island
True, but if you use a tapping motion with it, you can successively get it to go deeper and drill a straight-ish hole with one. The taper behind the burr will prevent it from snapping if you accidentally go a little off angle when hand drilling.
NC Rick
Asheville
If I was buying a drill for that, I would first try an expendable standard dill and if that didn’t work, I would buy a carbide drill made for hard metal. The hard metal bits are a type of spade drill with no flutes and support the tip better. Those drills are also shorter so less likely to break. I’d use what ever drill press device I happened to have and retract often during the drilling operation to blow out the crud. I’d be amazed if that didn’t work fine. You don’t want a lot of side force of those drills.
N
nes999
IL
So I had some extra time today and drove over there. I definitely think in the long run a dremel drill press would be handy. I did however drill quite a few fairly quickly free handing the dremel with the carbide bit.
egdede
Thanks 6PTsocket. I'm going to order some of those bits. Just because...
