Darkbreeze
So, sorry if this isn't the best area to post this question, but it seemed fitting.
I recently aquired a Snap On (Kwik Way) model 102 brake lathe and it seems the Crossfeed (Rotor) feed screw has a bad spot and catches every so often. Kwik Way is apparently no longer supplying parts for the model 102 or 104, or any other machines, which means Snap On has no source for them either. (Go figure, the local truck rep assured me, although I didn't get it from him, that Snap On would have parts available for this machine, pfft. Right.)
Anybody have a good recommendation on who I can contact in regard to potentially having a new feed screw fabricated, or whether somebody might have an idea if this is a more common screw potentially used in some other applications? I don't mind paying a fair price for the part, even if it requires somebody custom fabricating it as a one off, but it needs to be the real deal with a good quality final product. Any ideas are much appreciated.
Feed screw OE part number is 102 (or 104, depending on machine, but both are the same part) -1026-50 Assy, Crossfeed Screw RH
Thanks.
Thanks.
