South Bend 10x48 engine lathe
Techie1961
Pickering Ontario Canada
Ajax, Ontario
Price
1200
We have had this South Bend lathe in the family for many decades and I have no use for it now as I have a larger one. It is mostly complete and runs fine. There is some surface rust on the exposed areas due to storage in a large shop that isn't heated and there was condensation. This will polish out fairly easily.I tried to cover it with ATF but it didn't work out.
110 volts, single phase. Just plug it in and go. Can be delivered on a flat bed trailer if local but will need someone at the other end to remove from trailer.
You can use it as is or do a restoration on it. You won't find many that are this complete.
PS I am open to suggestions that I am off base with the price. I did a bit of research and this seemed about right for Canadian Dollars.
