South Bend Metal Lathe
Maui
Upstate NY
I got this South Bend metal lathe home a few hours ago. It was listed locally on FB Marketplace, and to my amazement the gentleman who had it called me first. It's missing the motor, switch, and the chuck. But that isn't any problem for me since I have all of them. To my delight it has the dual lever quick change gear box and the original South Bend taper attachment, and both appear to be in excellent working condition. What really surprised me is that this lathe came on the original factory South Bend steel bench, which is something I've never even seen before. The fellow who owned it never got it running. I'll probably have it up and running some time next week.
Maui
Upstate NY
Thanks! With all of the people who I knew would be drooling at a chance to buy this I was SHOCKED that I got a call back. The previous owner is a great guy. I'm just really happy I ended up with it. If you look at the lower right hand side of the last photo (you may have to enlarge it) you can see the South Bend badge riveted to the bench leg.
Maui
Upstate NY
It is a 9” lathe, yes. Any idea what year that 16” South Bend is that you have isb?
tom in nh
Nice that it has the v-belt drive and thread dial also.
What is the current going rate for a setup like that?
isb cornbinder
I know that the taper attachment alone is worth at least $600.
I do not have a taper attachment for either of my lathes. I would guess that I might have used a taper accessory 1 or 2 times in 40 years. For the times I needed to machine a taper, I was able to turn the compound and cut the angle. The last time was when I made a crowned flat-belt pully for my Canedy Auto drill press.
A friend was looking for a nice South Bend lathe. The first words out of him for years, was "taper attachment". He has had his SB for more than a decade and he has never used what he thought was a deal-breaker important option.
I think the taper attachment is important because it improves the resale of the lathe to the next person fixated on an ability to machine tapers. Keith
Rucker and Adam Booth have videos on the set-up.
Try to not miss a good deal on a lathe because it is without the taper attachment.
paulsomlo
Northern Colorado
That's a common sentiment - unless you need to turn a long taper, it never gets used.
Maui
Upstate NY
Several years ago I restored a Reed 324 1/2 Coachman's swivel jaw vise. The taper pin was missing when I bought the vise, and lots of different colors of paint had been slopped all over it. I stripped it down to bare metal, dug out all of the pieces of wood that had been jammed into the hole of the swivel pin, painted it and then clear coated it. I machined a pair of new taper pins for it on a South Bend 10K metal lathe that I used to own that had the very same factory taper attachment that the lathe I just purchased has. I made one pin from brass, the other from steel. Using the taper attachment made it a much easier job than it would have been otherwise. I regretted selling that 10K lathe, and definitely missed having the taper attachment available to me. This is one of the reasons why I was so happy to find this 9" South Bend lathe.
By the way, I only paid $100 for everything, and that includes the factory bench.
isb cornbinder
5 years ago I bought a dusty Myford Super 7 for $100. This Myford Super 7 came with many accessories I started to clean the Myford up. I was going to set it up next to my otherSuper7. A random visitor stopped by the shop and left with the second "7".
I did not give the Myford away.
