I've attached some pictures of my garage concrete spalling significantly, exposing rusted rebar. I'm trying to tackle the repairs myself and needed some input to ensure I'm on the right track. In the process, I've found a hollow space below the concrete slab. I have a company coming to assess the extent and if there are any foundation issues present. Here are the steps I've mapped out based on the forums I've read. This seems really overwhelming but all I've read makes me feel like I'm capable of completing this project without shelling out several thousand dollars for pros, barring any significant foundation findings from the assessment.
1. Demo: tear out all the loose, hollow-sounding concrete
2. Fill space beneath concrete slab using https://www.secureset.net/product/secure-set-spray-foam/ covering 16.6 ft3 (supports 5,000 lbs/ft2, cost ~$500
3. Buff out the rust on the rebar, prime with Corroseal Rust Converter, cover with Seymour Green Epoxy Rebar coating
4. Clean garage floor with Rustoleum Cleaner/Degreaser/Etch
5. Fill holes around rebar concrete or FiveTon Epoxy https://www.legacyindustrial.co/products/fiveton-epoxy-patch-kit/ large kit covers 16-18 ft2 @ 0.25 inch depth, cost ~$200 Question: Is it better to use concrete bond, fill with concrete, and put FiveTon over the top or should I fill entirely with FiveTon?
6. Cover floor with Rustoleum Recoat Primer ~$100
7. Cover floor with Rustoleum RockSolid Coating ~$200
8. Cover floor with Rustoleum RockSolid Clear Topcoat ~$200
Question: Are these steps correct and are there better/more cost-effective options available? Am I crazy to think I can do this effectively myself and not compromise the integrity of the garage supporting the weight of our cars (~3,400 lbs and ~4,800lbs)?
Thank you so much for all the help.
