Spanning 10' with unistrut
REKIII
Wisconsin
What will the results be if I span 10' with Unistrut and hange a light in the middle of it?
I'm trying to not hang the lights from long cables, to avoid the sway. But I think a 10' span of unistrut might bow.
bloomingtonmike
Bloomington, IL
Bigger stuff is 1 5/8".
Unistrut bought locally comes in 10' lengths although you can order 20' lengths online in bulk I believe. Unistrut will not bow under its weight + most fixtures you would use in a shed. If for some reason you have some that would bend it, and it is open air span where you cannot attach the unistrut in various spots, bolt a piece of angle iron to the top of the unistrut across the open span.
Maybe easier to just span the length with a 2X.
cybrdyke
USA
1 5/8 x 1 5/8 strut, in a 10' span (supported at both ends) will hold 340 pounds if evenly distributed across the span. If it's just a concentrated load at one point, then it will hold 170 pounds, with a deflection of 1.1 inches.
R
REKIII
Wisconsin
Excellent info. Thank you.
How about if I mount it in a 90° orientation....like how you bolt it to a wall, but still in a free span?
richpa
London England
If you bolt 2 lengths of unistrut sections back to back this will increase the rigidity and will also increase the weight bearing load.
