MushCreek
As I mentioned in another thread, I always carry a spare hub and bearings as well as a tire and wheel when traveling long distances with a trailer. I've mounted them a number of ways over the years, and finally got around to putting one on my boat trailer. Usually I mount them so the tire is vertical, but this trailer and tow vehicle are low, so I worry about the tire hitting going over a tall bump such as a RR crossing. I made a mount to hold it horizontally instead. In the past, I've just bought a stub axle, but since I'm retired and poor, I made one out of steel I had on hand. Any excuse to fire up the lathe and cut threads! Then I welded it to a piece of plate, and a U-bolt holds it on the trailer frame. If I have a bearing failure, it's easy to just slide the whole assembly off of the mount and slide it onto the axle. Of course, I can just change the tire if I get a flat. The only drawback is that I will have to slide the boat back a couple feet to remove the spare, but the boat only weighs 140 lbs., so NBD.
