Spark Plug Boot Removal?
BQuicksilver
What tools do you guys have for these? 90% of the time I can get them by hand, but the ones I can't are a nightmare. I have a pair of "plug wire removal pliers" that are cheap/flimsy and really just damage the wire. Is there a better option?
tcsalvage
brogue, pa
if they are old and stuck on tight all the removal tools in the world won't get them off. i have good luck with 45 degree needle nose pliers if i can't get in with one of the pullers. grip the wire through the boot on to the plug connector. when you install ANY plug wire put some dielectric grease on them so they won't stick the next time you take them off.
BQuicksilver
Usually it's some neighbor's car that hasn't seen plugs since 1998 that gets me.
Old Donn
9 times out of 10, you're gonna trash any wire you need pliers for. Have a new set of wires at the ready.
outcast
my boss would kill me, if i did this.
get a good set of boot pulling pliers. there IS a difference.
Jeeper
Round Rock, TX
I use a pick with a right angle at the tip. It destroys the wires but I am usually replacing them anyways.
GirlnAgarage
Texas
I use a boot puller
+1 !
Sometimes the grease will make "too goof" of a seal between the boot and the plug trapping air under the boot. "Burp" this air out or it might push the boot off !
shampoop
SW Washington
http://www.tooltopia.com/lisle-52990.aspx
they make specific tools for this. i use this. if they are old when you grab it give it a couple twist that helps break apart any vulcanization that might of occured.
I have those, and something similar from blue point but at a 45 degree angle. I've really not satisfied with either of them. I hate trying to remove ****** old plug wires. the screwdriver style one pictured earlier looks pretty cool.
DrkMtnDew
go to HF. buy the 3 pack of hose puller pliers and a can of the rubber grip dip. dip the jaws of the largest pair a couple of times allowing time to dry in between coats. work very well on every plug i've had come in.
shampoop
SW Washington
Sounds like it would work great. My holy grail would be a tool that would work on the firewall side of transverse v6 engines. Especially those in minivans.
Gary S
Bismarck, ND
RIGHT answer.
If you have trouble removing the wires, just yank them off with your hands or a pliers. Any spark wire that is difficult to remove needs to be replaced anyway, so why spend money on tools you have no need for?
New wires are cheaper than tools, and they fix the problem for years.
DrkMtnDew
A cheap tool can be long paid off if you aren't having to replace every single problem wire that rolls through the door. besides sometime you just have to get a stuck boot off safely because the customer refuses to buy new wires.
BQuicksilver
RIGHT answer.
So just consider them all destroyed rather than make an effort to remove them properly? And tight wires most certainly don't need replaced just bc they were tight.
RIGHT answer.
:wtf: :headscrat
I don't think so...
smogtech
alot of spark plug wires can be saved if you just give them a twist before you attempt to pull them off. what happens over time is the heat creates vulcanization. which is the rubber adheres to the spark plug. if you give it a twist first it will break it. trust me wires can get stuck pretty fast. i was working on a 2000 regal gs i had just put wires on it and drove about 5 miles and needed to remove a few wires again and without the pliers that wasn't going to happen.
if you needed to replace every set of wires you pulled off at the job you would be unemployed very fast.
V70R
Portland, OR
For any vehicle with a deep well plugs I use these:
http://www.ecstuning.com/Volkswagen-Golf_III--VR6_12v/Engine/Tools/ES5422/
http://www.fourseasontuning.com/product.php?id=771&product_code=32Z
***** all you want about cost. Loose a plug wire in a deep well block and it never ends well.
For std. wires I use the Snap-On pullers.
You spent $40+ on a POS plastic wire puller that was stock on a MK3/B3/B4 Passat and Corrado hood props? Yikes. You can purchase the factory s.s. Hazet with grip handle tool for less then $40, and the more affordable SP Tools s.s. T-Handle version for $30.
Not exactly. Rubber and silicone don't "vulcanize " to ceramic.
What you are getting is a vacuum seal, The heat expands the air in the spark plug grooves and it will leak past the "Seal' as in that direction it's a poor seal. (Think mason jar lids and their seal..) as it cools the air contracts and pulls the boot tight.
If you pull on the wire or boot, particularly from the rear, it also starts to stretch the boot lengthwise, and the seal and grip get tighter. (Think of the Chinese handcuffs you played with as a kid)
If you grip it near the bottom edge, or in the case of the hook tool GirlnAgarage posted, from the bottom edge, it tends to expand the boot and break the seal.
Dielectric grease helps for making the grip less secure, however it also makes the slight vacuum seal even better; but, I think making the grip less secure overshadows the vacuum. Use the grease.
VWandDodge
RIGHT answer.
:wtf: :headscrat
I don't think so...
Agreed. Di-electric grease + the proper tools = money saved.
BigAl62
suburbs of Chicago
This is what I use (but not from Harbor Fright!)
Quercus
Bumping this thread! I got into my Suzuki Grand Vitara spark plugs for the first time yesterday, and struggled mightily with (and tore 2) of the plug boots. Ultimately twisting with 2 pairs of needlenose pliers busted them all loose. New parts are on the way, but I should have checked this thread first!
jethro29
central delaware
try spraying the spark plug boots with brake clean(on a cold engine only) first,then give them a twist and pull.it really does help a lot.
