Spark plug end assembly
Arne73
I just got a new coil for my mower and the plug ends require some assembly.
I've Googled and searched YouTube for guidance on this type but come up dry- any guidance from the Garage? 20210411_102732.jpg
Sent from my SM-G960U using The Garage Journal mobile app
kbeefy
Harington, Eastern Washington
Feed the lead through the boot.
Strip the outer insulation back about an inch, fold the shielding back over the outer insulation to expose the inner insulation.
Strip the inner insulation to expose the core.
Crimp the terminal to the inner insulation, I think you fold the core back over the inner insulation to capture it with the crimp.
Pull the boot over the terminated end and install on spark plug.
mikegt4
sw ohio
The little prong pierces the wire and the top of the spark plug snaps into the springy part.
Run the wire through the rubber boot first.
Use pliers to push the prong into the wire, make sure it hits the conductor inside the wire.
Slide the boot back over the end of the wire and you are done.
