Spark plugs
Lkdelta
40 mi.east of syracuse
a spin-off of the Very Interesting Plug Situation
would it have mattered which brand of plug was in there?
probably just in there too long?
Gary S
Bismarck, ND
I'm guessing spark plug brand doesn't matter. Problems like this are about 95% due to aluminum heads. Any brand might act the same.
fivespdcat
You gotta show pics of the plug. I can't say what caused it without seeing the plugs....
rwhite692
Central Valley, CA
Is there a recommended brand or type?
I use this stuff from Permatex:
http://www.permatex.com/products/automotive/lubricants/specialty_lubricants/Permatex_Anti-Seize_Lubricant_a.htm
A highly refined blend of aluminum, copper and graphite lubricants. Use during assembly to prevent galling, corrosion and seizing and to assure easier disassembly. Temperature range: -60°F to 1600°F (-51°Cto 871°C). Salt, corrosion and moisture resistant – ideal for marine use. Non-aerosol version meets Mil Spec #907E. Aerosol - Level 3*
Lippyp
Shropshire, UK
The plugs on my 01 blazer were the original AC Delco's at 66K miles, when I changed them two snapped in two with the ceramic insulator coming off. When the new AC Delco irridiums went in they got a smear of anti-seize even htough they all unscrewed fairly easily. No point in tempting fate. I don't think brand matters a damn if they are left in too long with no anti-seize.
