brats.n.harleys
ok, i wired up 8 speakers in the garage. they have multiple wires on the back to be used for 70volt, 8 ohm, and some other types. the amp i have also has multiple configuations to run either 70volt, 8 ohm, etc... i wired them all up using the 70 volt config. with 24 gauge ( i know its too thin, im replacing it tonight with 16) when the volume is low, there is a constant hum from the speakers. So, my questions are..
is the hum just caused by the wire being too thin?
is 70 volt better than 8 ohm? from what i can find (and understand) online, you cant link a bunch of 8 ohm speakers together, buy you can do that with 70 volt. but 70 volt is mono only not stereo (not even sure what that means exactly)
just want to have loud music and tv in the garage.. any help is appreciated
