Special snap ring tool?
f121
UK
I was recently faced with a snap ring on a gearbox pinion shaft had didn't have holes to locate a tool in, just fairly pointy machining on the ends. I managed to use my regular knipex snap ring (circlip if you're British) pliers, but it was very very fiddly and frustrating.
Is there a special tool for this style snap ring? Maybe spreading pliers with two concave cups to locate the points of the snap ring?
Grant Gunderson
Bellingham, WA
Yes. I have 4 different versions for those.
The ones one the left, work for those, but are designed more for the ones with flat ends.
Knipex special Circlip pliers.
The middle ones are specific for your type of ring. Knipex 4521200
The last ones work for both types. They are made by Wilde for Snapon, Proto, etc. I bought the Proto version as it was cheapest at the time. AKA horseshoe washer pliers. I also have these Wilde ones as well. They are for larger sized rings, so depends on the shaft size you are dealing with.
I wouldn't say, one is better than the other. I have all of them, as I have ran into multiple situations where one works the best and the others dont. If its a large, thick ring, get the compound. If its smaller rings, the other options are better.
F
f121
UK
That's brilliant, thankyou. I'll order a set of the knipex and the proto to cover my bases.
ecotec
Get a “robust” one! The only Snap On tool I ever broke was that plier type on a transmission ring like yours.
They have a 14”ish version for that ring. Lock ring pliers 700a. They might be called something different now.
