Speed control for Baldor buffer?
Dad Was A Racer
Bryan, Texas
I have a Baldor model 410B buffer that is simply too fast and too powerful for the size pieces that I am typically trying to polish, and I would like to slow the motor down with a speed control. Is this possible?
It's a 1.5hp, single phase, 60hz, 115v motor drawing 13.8 amps, so it requires something with a relatively high capacity. I tried one of the cheapo router speed controllers from HFT and it immediately blew the fuse in the controller (of course).
FWIW the motor currently runs at 3600 rpm.
Milton Shaw
Router speed controls, drop the voltage to make the brush type motor run slower. An induction motor like that requires you to control the frequency (Hertz) to change the speed. That is what a VFD used with a three phase motor does. That is a big buffer so any controller will have to be pretty stout and will be hard to find.
exmaxima1
Midwest
No practical solution for a single phase motor.
AFAIK, though, polishing of metal is typically done at SFPM of 5000-7500. Your 3600 rpm polisher should be fine with up to 10-inch wheels. What are you polishing?
metlmunchr
You can't really do much to control speed on a single phase induction motor. What diameter wheels are you using now? Smaller wheels slow the surface speed which is the equivalent of running the motor slower.
I've got a 2hp 3 phase Baldor buffer but mine is 1800 rpm. Depending on what I'm working on, I use wheels varying from 6" to 12" diameter, and haven't had a need to add a vfd.
metlmunchr
Yeah, that's an option, but at 700 bucks a pop for Baldor buffers, it sure isn't an economical option.
dogdog
dependents on the type of 1PH AC motor you have I think on that buffer.. VFD are for 3PH motors if I am not mistaken... the router speed controllers are more for brushed motors not for AC induction motors ... it's basically a triac dimmer...
American Locomotive
Rhode Island
As others mentioned, the easiest solution is to put smaller wheels on it. The surface speed of the wheel scales linearly with diameter. So going from a 12" to a 6" wheel would be the same thing as slowing the motor down from 3500 RPM to 1750 RPM.
