Speed Key for a lathe chuck
tool_scrounge
Southern California
The stock lathe key that came with my 3 jaw chuck is great for tightening. But is is a pain the wrist when making large lathe jaw adjustments. Turning it 1/2 a turn at a time is also pretty slow. So my goal was to make a key that could be operated with one hand quickly while my other hand was supporting the round stock.
I had a spinner handle with way too many stripped set screw holes in the junk pile. I had been debating on recycling it. But I figured sooner or later I would find a use for it. The lathe key was a 0.44" square drive, so a 1/2" socket extension would be good starting material. I ended up using an old Craftsman 6" extension as the shaft was 0.52" in diameter and the spinner handle had a 0.50" bore.
Milling the extension flats down to 0.44" square was pretty easy with sharp tooling and a machinist square. Lathing that shaft diameter down 0.02" was harder than I expected. It turns out the Craftsman extension is not very straight. It is bad enough that you cannot turn it with carbide tooling as the interrupted cut breaks the carbide tip. But high speed steel lathe bits work just OK. Not great finish but good enough for this application.
I press fit the modified extension into the handle with added Loctite 648 retaining compound. It holds very well. I will use the stock handle for the final clamping on metal, but the speed key good enough for for final clamping on plastics.
Originally I left the spring loaded ball in the extension, but it made inserting the key into the chuck a bit too difficult. So I milled out the back are removed the spring. The key is sized close enough that it stays put in the lathe chuck even without the spring loaded ball.
Overall it works very well.
As with any lathe key, you do need to remove it before turning on the lathe for safety sake.
RoninB4
Under My House
Was a good solution for wrist pain. A low profile T-key will also work if you can develop finger dexterity in you left hand. Your solution is a bit more elegant.
MushCreek
Upstate South Carolina
You could always make an adapter to put in a cordless drill if you're making frequent large changes. Cordless drills are handy for this stuff; I've seen adapters to raise/lower the knee on milling machines, and I use one to raise and lower my boat with a worm gear winch.
T
tool_scrounge
Southern California
I thought about that as an alternative solution. I am not using the lathe every day and decided on going with a simple solution that does not take up much space on the lathe headstock. I also would not need to worry about battery charge levels.
Zeus36
Ventura, California
I like your spinner handle better than the one I made with a ball bearing. This picture is not the one I made but the photo I used to build mine. Due to your spinner knob design, I may add a counter weight on the plain side of the handle.
T
tool_scrounge
Southern California
If I was going to go electric like @MushCreek referred to, I would probably use a straight low geared power screwdriver. If something unexpectedly grabbed, the screwdriver would rotate in your hand and automatically shut off as your thumb came off of the switch. It would not twist your wrist as much compared to using a drill one handed .
One downside is that it is round and will sooner or later roll off of the headstock!
